No Xilinx Design Tools folder in Start menu after installing Vitis on Windows 10
I downloaded Xilinx_Unified_2019.2_1106_2127_Win64.exe and (since I don't have admin permissions) my IT person ran the web installer on my brand new Windows 10 Pro laptop (no previous Xilinx sw installed). Vitis and Vivado appeared to download and install without problems, using the license file shown below. I see lots of stuff under C:/Xilinx/Vitis/2019.2/ and C:/Xilinx/Vivado/2019.2/ . The problem is that I don't see a Xilinx Design Tools folder in my Start menu.
The only other thing that might be notable is that I have Windows 10 Pro version 1909 on my machine, and ug973 lists "Microsoft Windows 10.0 1809 Update; 10.0 1903 Update (64-bit), English/Japanese" under Supported Operating Systems.
C:\Xilinx\.xinstall\Vivado_2019.2\xinstall.log is attached. There's a java.lang.NullPointerException at the end of it.
What do I need to do to complete the installlation?
EDIT: The two most noticeable problems are that the Xilinx Design Tools folder is missing from the Start menu, and that there are no icons for most of the executables under C:\Xilinx\...
If I click on C:\Xilinx\Vitis\2019.2\bin\vitic.vbs or C:\Xilinx\Vivado\2019.2\bin\vivado.bat, they actually run. So I'm thinking that the java.lang.NullPointerException caused the final steps of the installation to not run, which included setting up the Start menu and seting up the .ico files.
Has anyone installed Vitis on a completely fresh machine? This new Vitis distribution might depend on something that was set up by previous Xilinx tools installations.
I'm still looking for suggestions for how to complete this installation.
# ----- REMOVE LINES ABOVE HERE --------------------------
# This license is valid from Wed Jan 29 00:51:47 UTC 2020.
# This is license NODELOCKED to HOSTID=80f70592;
# there is no need to run lmgrd for this license.
# This is a permanent license generated on Wed Jan 29 00:51:47 UTC 2020
INCREMENT ISE_WebPACK xilinxd 2021.01 permanent uncounted \
6A7BE0397356 \
VENDOR_STRING=jankok,ISE_WebPACK,software,permanent,_211319274_1777523930_0_938 \
HOSTID=ANY ISSUER="Xilinx Inc" START=29-Jan-2020 TS_OK
INCREMENT SDK xilinxd 2021.01 permanent uncounted 40B0667BAD14 \
VENDOR_STRING=jankok,SDK,software,permanent,_211319274_1777523930_0_168 \
INCREMENT Analyzer xilinxd 2021.01 permanent uncounted 78FC7585281F \
VENDOR_STRING=jankok,Analyzer,software,permanent,_211319274_1777523930_0_021 \
INCREMENT HLS xilinxd 2021.01 permanent uncounted 8A2DB870F0D1 \
VENDOR_STRING=jankok,HLS,software,permanent,_211319274_1777523930_0_664 \
INCREMENT V_WebPACK xilinxd 2021.01 permanent uncounted E48CE1A7B48E \
VENDOR_STRING=jankok,V_WebPACK,software,permanent,_211319274_1777523930_0_041 \
INCREMENT Embedded_SDK xilinxd 2021.01 permanent uncounted \
2F9EB0D9B6EB \
VENDOR_STRING=jankok,Embedded_SDK,software,permanent,_211319274_1777523930_0_806 \
HOSTID=DISK_SERIAL_NUM=80f70592 ISSUER="Xilinx Inc" \
INCREMENT ISE_Embedded_Edition xilinxd 2021.01 permanent uncounted \
F307239FBB38 \
VENDOR_STRING=jankok,ISE_Embedded_Edition,software,permanent,_211319274_1777523930_0_848 \
#  The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE ISE_WebPACK xilinxd 2021.01 463DF6C71E30 COMPONENTS="SDK \
ChipScopePro_SIOTK ChipscopePro WebPACK XC7Z010 XC7Z030 HLS \
xps_tdp XC7Z020 PlanAhead" OPTIONS=SUITE
PACKAGE Embedded_SDK xilinxd 2021.01 7C97B912906E COMPONENTS=SDK \
OPTIONS=SUITE
PACKAGE ISE_Embedded_Edition xilinxd 2021.01 778E5AF9F3D4 \
COMPONENTS="SDK ChipScopePro_SIOTK ChipscopePro ISE XPS ISIM \
# ----- REMOVE LINES BELOW HERE --------------------------
Re: No Xilinx Design Tools folder in Start menu after installing Vitis on Windows 10
Were you able to find a solution for your problem. I am looking at the same problem here.
It still looks like there is a bug in the Vitis installation script. Would be nice if Xilinx would fix it and/or publish a workaround.
Anyway, I created shortcuts:
C:\Users\JKok\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Vitis => C:\Xilinx\Vitis\2019.2\bin\vitis.vbs
C:\Users\JKok\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Vivado 2019.2 => C:\Xilinx\Vivado\2019.2\bin\vivado.bat
and have been able to use Vivado and Vitis without encountering other issues.
Hi jankok,
I have come across the same issue. I downloaded vivado 2019.2, however nothing I can run has been downloaded. As for your solution, I could not get actually what you have really done to fix the issue. Did you copy and paste files from one directory to another?
Alper
If "nothing I can run has been downloaded" it sounds like your installation failed a lot earlier than mine (which failed near the end, perhaps before the Xilinx tools folder could be created in the Start folder). Check your C:\Xilinx\.xinstall\Vivado_2019.2\xinstall.log and see if it ends earlier than mine. Maybe check that the signature on the install file is correct, uninstall and try to reinstall.
I didn't copy any files, I just created two shortcuts in the start menu pointing to the executable files.
Good luck!
