yhy.xilinx
No card is found issue while running an application
I am having issue while running an application on my card. After connecting to my device and using "./host.exe krnl.xcbin" command, I am seeing the following:
HOST: petalinux
EXE: /mnt/working_dir.exe
[XRT] WARNING: No devices found
[XRT] ERROR: No devices found
../libs/xcl2/xcl2.cpp:40 Error calling err = cl::Platform::get(&platforms), error code is: -1
 I used "sudo /opt/xilinx/xrt/bin/xbmgmt flash --scan" command to check, it also states this error: "no card is found!".
How am i supposed to let it recognize the card?
Is the problem sourced from the platform generation process? If so, which step must have been skipped? I utilized many different source while generating it because the info about this topic is so distributed.
Tags (3)
yhy.xilinx
I had used those links and actually they were working properly. I was generating the platfrom as it must be. The reason of the problem was the outdated rootfs partition of the sdcard. It was not updated properly with sysroot.
Thanks for your replies.
stephenm
what device are you using; Alveo, Zynq Ultrascale?
yhy.xilinx
zynq ultrascale/ zcu104
stephenm
yhy.xilinx
I tried different ways.
1) I used this link(https://github.com/Xilinx/XRT/tree/master/src/platform) and created my platform and build a platform project by the use generated xsa file. It was built without a problem. However, I got the error. I utilized the tcl command and created xsa first and then I used peta-build.sh to create using petalinux.
2) I followed this link: https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk375818786.html#hog1570652702356 (and this https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk356017304.html#jvn1570652701832) . It shows how to create hw and sw platform and build the project. I got the same error after building implementation and running it on the card.
3) The only difference of my implementation with the link you provide is that I am creating a platform based on linux instead of standalone option because the link I provide above guided me so.
stephenm
can you share your xsa file please?
yhy.xilinx
I attached two of the xsa files I am using above(to the first post message).
stephenm
Can you try the script here to generate the XSA:
https://github.com/Xilinx/XRT/tree/master/src/platform/zcu104_base
For example:
Launch Vivado, and source the zcu102_base_xsa.tcl
To create the Linux Image, use the steps here:
yhy.xilinx
I have used these links and attempted a lot, it did not work for me. After sending the files from my computer to the board, i am running init.sh file which must set the XRT but it doesn't. I do not know why. Therefore I am writing the "export XILINX_XRT=/usr" command by my hand and set the XRT. Later, when I run with "./sth.exe and krnl_name.xclbin", I get this error. They did not work. Do i have a problem with the .xsa generation? If so, how did you realize it? by looking at what?
stephenm
I generated the XSA by using the script here:
Launch Vivado 2019.2, and source the zcu104_base_xsa.tcl
The Petalinux project steps are seen here:
The same steps are seen here (with added screenshots):
https://www.hackster.io/news/microzed-chronicles-vitis-sw-platform-fd3921137bcf
yhy.xilinx
stephenm
Ok great. can you mark this as solved then?
