On windows I get link error : the command line is too long
trying to migrate my project from vitis 2019.2 to vitix 2020.1
But the project using 2020.1 is failing in link stage on : the command line is too long
I have note that during linker stage : aarch64-linux-gnu-g++ 2020.1 is using the command line
BUT aarch64-linux-gnu-g++ 2019.2 is using collect2.exe
can you please explain how to force using collect2.exe in vitis 2020.1 in order to avoid the error : the command line is too long
hongh
In Vitis, only SDK flow is still supported in Windows. The Edge flow and DC accelerate flow is only supported in Linux.
Sorry, but what does it means The Edge flow and DC accelerate flow? can you send reference for documentation..
I just migrate my project from vitis 2019.2 to vitis 2020.1, why the linker failed?
Does it means not to use Vitis 2020.1
