olevr
Petalinx Tools 2019.2 won't install on Ubuntu 18.04.3 LTS
I want to install the Petalinux Tools 2019.2 on Ubuntu 18.04.3LTS.  Following the instructions in UG1144 I have installed the prerequisites in Table 2 and I have changed my default shell command to 'dash' with 'sudo dpkg-reconfigure dash'.  After downloading the installer I tried running it with
./petalinux-v2019.2-final-installer.run
and got
bash: ./petalinux-v2019.2-final-installer.run: Permission denied
Then I tried running with the shell command:
sh ./petalinux-v2019.2-final-installer.run
and got
./petalinux-v2019.2-final-installer.run: 8: ./petalinux-v2019.2-final-installer.run: function: not found
PetaLinux installer.
Usage:
petalinux-v2019.2-final-installer.run [--log <LOGFILE>] [INSTALL_DIR]
Options:
--log <LOGFILE> specify where the logfile should be created.
it will be petalinux_installation_log
in your working directory by default.
[INSTALL_DIR] specify the directory where you want to
install the tool kit. If not specified,
it will install to your working directory.
./petalinux-v2019.2-final-installer.run: 23: ./petalinux-v2019.2-final-installer.run: Syntax error: "}" unexpected
What is the problem?
bartokon
They do install... I have petalinux on my ubuntu 18.4 lts.
Did you install all required packages listed in petalinux 2019.2 install guide?
Did you tried "sudo ./peta.run"? And "sudo chmod 777 peta.run"?
Maybe you are installing petalinux in some kind of root only folder? Try make folder like /home/user/Petalinux/ and install it there.
Also ubuntu 18.4 lts doesn't support some 32bits libraries so first you need to add i386 architecture to your system and install 32bit packages/libraries.
It all can be done via "apt get" after you add i386 architecture.
Good luck making it work.
bartokon
hamza.bendaoudi
Hi @olevr ,
It's mentionned in UG1144, page 9, that the supported OS for Petalinux 2019.2 is limited to Ubuntu 18.04.02.
Ubuntu Linux Workstation/Server 16.04.5, 16.04.6, 18.04.1,18.04.02 (64-bit)
Maybe you need to downgrade your Ubuntu version from 18.04.03 to 18.04.02.
Good Luck,
Hamza.
olevr
Hi bartokon,
Thanks for your reply.  I ran chmod 777 on the .run file and everything seems to have installed.  The reason I didn't run chmod 777 before was because of this note in UG1144, page 11 : Note: Do not change the installer permissions to CHMOD 775 as it might cause BitBake errors.
Perhaps that note should be removed.
