n3rdx
Printing C/C++ source code from VITIS IDE editor
VITIS IDE looks like Eclipse. Works like Eclipse that usually allows me to print code that I have written, perhaps to a PDF file for documentation purposes.. I wanted to print to a printer some application code (C or C++) from IDE. Isn't there a print function in a menu somewhere? If not, is it possible to get a plug in to pretty print code that I have written/commented with DOXYGEN markers? Or does VITIS support direct generation to Doxygen?
My configuration:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
com.xilinx.product=scout
ds.delayed.keepInstances=true
eclipse.application=com.xilinx.ide.application.ui.rcp
eclipse.buildId=2020.1
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
Tags (2)
hongh
It looks print.. button is not added in Vitis IDE.
Could you try to open the source files with the 3rd part editor and print it?
hongh
The developer thinks the user can print the source code in 3rd party editors or Vivado. They intend to keep the menu concise and refuse to add print function in Vitis IDE.
joe306
I have the same problem in Vitis 2020.1. I get an error message when trying to print.
Joe
hongh
Hi, @joe306
VItis IDE doesn't contain Print button. Actually you are using Vivado IDE.
joe306
Oops, I made a mistake. I have the problem in Vivado 2020.1 not Vitis. I'm sorry for the post reply. Joe
joe306
Yes, your are correct. I wasn't thinking when I entered this reply. Sorry for making a mess of things. I have problem in Vivado 2020.1 printing. Respectfully, Joe
hongh
Hi, @joe306 ,
Doesn't matter. I've seen your new post and assign it to Design Entry Board.
