lygw
Questions about reading data from HBM
If I need to read 512 bits from HBM in Alveo U280, which choice should I take to read fastest?
1) read 512 bits(kernel ports have a maximum width of 512 bits) from one HBM channel(The AXI width per channel for HBM is 256 bits in Alveo U280)
2)separately read 256 bits from two HBM channels in parallel
3)separately read 128 bits from four HBM channels in parallel
Thanks for any help!
hongh
The first method needs to visit HBM twice(two period) to read 512bit data back, and the latter two methods only use one period to read the data. So I think the the latter two methods will be faster.
hongh
