Running Vitis Tools in a Docker Container
In order to overcome OS version compatibility issues and specific errata, is it a supported configuration to install Vitis on a CentOS 7.5 docker container running on a physical Ubuntu 18 host, or does it need to be a VM?
We currently do not support Vitis in a docker container. While the installer will not prevent installation in such an environment, we cannot provide any support for issues that arise from docker configurations.
Please don’t forget to reply, kudo, and accept as solution!
Hi @e_ensafi
I know that Xilinx doesn't support "running Vitis Tools on Docker container".
However I already installed and used it at my own risk.
Hope it helps.
Best regards,
