meven
SDAccel 2018.2 fail to link libdpi.so
I'm trying to run HW emulation for the vadd example in SDx but I have an error :
14:18:56 **** Incremental Build of configuration Emulation-HW for project vadd ****
make -j1 incremental
/media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/xocc -t hw_emu --platform xilinx_kcu1500_dynamic_5_0 --save-temps   -l --nk krnl_vadd:1:krnl_vadd_1 -g --messageDb krnl_vadd.mdb --xp misc:solution_name=link --temp_dir krnl_vadd --report_dir krnl_vadd/reports --log_dir krnl_vadd/logs --remote_ip_cache /home/sinitame/SDX/ip_cache -o"krnl_vadd.xclbin" krnl_vadd/krnl_vadd.xo
****** xocc v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: [XOCC 60-629] Linking for hardware emulation target
WARNING: [XOCC 60-1140] Rule service exception in startRuleCheckSession. Design Guidance report may not be produced. Exception: write: Broken pipe
INFO: [XOCC 60-895]   Target platform: /media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
INFO: [XOCC 60-423]   Target device: xilinx_kcu1500_dynamic_5_0
INFO: [XOCC 60-825] xocc command line options for sdx_link are --xo krnl_vadd/krnl_vadd.xo --nk krnl_vadd:1:krnl_vadd_1 -keep
using /media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
extracting xo v3 file /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/krnl_vadd.xo
Creating IP database /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/sys_link/_sds/.cdb/xd_ip_db.xml
processing accelerators: /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/sys_link/iprepo/xilinx_com_hls_krnl_vadd_1_0
ip_dir: /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/sys_link/iprepo/xilinx_com_hls_krnl_vadd_1_0
/media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/xsltproc --stringparam xpath "spirit:component/spirit:name/text()" /media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/scripts/xdcc/xpathValueOf.xsl /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/sys_link/iprepo/xilinx_com_hls_krnl_vadd_1_0/component.xml
ip_name: krnl_vadd
Creating apsys_0.xml
INFO: [CFGEN 83-0] Kernel Specs:
INFO: [CFGEN 83-0]   kernel: krnl_vadd, num: 1, inst(0): krnl_vadd_1
Creating dr.bd.tcl
/media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/cf2xd: 4: /media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/cf2xd: [[: not found
INFO: [CF2XD 83-2203] Adding accelerator adapters...
INFO: [CF2XD 83-2200] Adding axi_interconnects...
INFO: [CF2XD 83-2201] Adding axi_stream_router for scatter-gather DMAs...
INFO: [CF2XD 83-2202] Adding axi_dwidth_converters...
INFO: [CF2XD 83-2208] Adding bus connections for logical connections...
INFO: [CF2XD 83-2205] Adding clock connections...
INFO: [CF2XD 83-2206] Adding reset connections...
/media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/cf_xsd: 4: /media/sinitame/Secure_HDD/Xilinx/SDx/2018.2/bin/cf_xsd: [[: not found
INFO: [XOCC 60-812] xocc command line options for vpl are -t hw_emu -f xilinx_kcu1500_dynamic_5_0 --nk krnl_vadd:1:krnl_vadd_1 --xp param:compiler.enablePerformanceTrace=1 --xp misc:report=type report_timing_summary name impl_report_timing_summary_route_design_summary steps {route_design} runs {impl_1} options {-max_paths 10} --xp vivado_prop:run.__KERNEL__.{STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS}={-directive sdx_optimization_effort_high} --xp param:compiler.enableRunInBitstreamGeneration=1 --xp misc:solution_name=link -g -s --remote_ip_cache /home/sinitame/SDX/ip_cache
****** vpl v2018.2 (64-bit)
Attempting to get a license: ap_opencl
Feature available: ap_opencl
INFO: [VPL 60-839] Read in kernel information from file '/home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/int/kernel_info.dat'.
INFO: [VPL 60-423]   Target device: xilinx_kcu1500_dynamic_5_0
INFO: [VPL 60-1032] Extracting DSA to /home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/vivado/.local/dsa
INFO: [VPL 60-251]   Hardware accelerator integration...
ERROR: [VPL 60-399] vivado failed, please see log file for detail: '/home/sinitame/SDX/vadd/Emulation-HW/krnl_vadd/link/vivado/vivado.log'
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [XOCC 60-398] vpl failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
WARNING: [XOCC 60-1140] Rule service exception in stopRuleCheckSession. Design Guidance report may not be produced. Exception: write: Broken pipe
makefile:82 : la recette pour la cible « krnl_vadd.xclbin » a échouée
make: *** [krnl_vadd.xclbin] Erreur 1
14:30:55 Build Finished (took 11m:59s.336ms)
When looking to the log file it seems that the error comes from libdpi with can't be linked. I attached the log file for more informations.
Same issue seems to be reported here #868024 :https://forums.xilinx.com/t5/SDAccel/Vivado-failed-to-link-libdpi-so/td-p/868024
I'm running SDx in a Debian (Strech) VM.
Any solution to solve this error ?
graces
Debian is not officially supported.
For Ubuntu, try to set environment variable CPATH to /usr/include/x86_64-linux-gnu.
You may also try to upgrade to 2018.2_XDF release, which should have fixed the issue.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
skotti
@meven, did you figured out what the issue is?
nahmad16
I have the same error when compiling vadd in hw_emu. Anyone with a solution?
graces
yanhan
@graces thank you ,
"set environment variable CPATH" works
