I have downloaded sdaccel environment、xrt、deployment shell,development shell,but still got this error,which says RXT requires OpenCL header files to be installed,can you give me some advice .
Did you take a look at UG1238 corresponding to your SDAccel version?
Make sure you are using supported OS platform and have installed required libraries and packages for the OS. These are documented in UG1238.
Also note to set up both SDAccel and XRT environment.
C Shell:
source <SDX_INSTALL_DIR>/settings64.csh
source <SDX_INSTALL_DIR>/xrt/setup.csh
Bash:
source <SDX_INSTALL_DIR>/settings64.sh
source <SDX_INSTALL_DIR>/xrt/setup.sh
C Shell:
Bash:
