SDSoC Cannot finish HLS Synthetisis
I have started using SDSoC with the reVISION stack lately on a ZCU102_es2. I have a Windows 10 64 bit.
I followed every step in the tutorial "http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.1" and everything went OK. I successfully compiled and run the Optical Flow example on the card and visualized the output using the generated files on SD Card.
After I tried editing the source code, I ran into some troubles. First, I had to change the SYSROOT. Then It said that I have some locked IPs knowing that my license is still active.
After rebuilding multiple times, I am stuck with this error. HLS cannot move the xFDenseNonPyrLKOpticalFlow function to HW. It works fine for read_optflow_input but the second function is problematic.
I provide the logs in attachments. The next is the Console output.
12:26:11 **** Build of configuration Release for project OF2_Cust ****
make pre-build main-build
sdsoc_make_clean Release
'Building file: ../src/optical_flow.cpp'
'Invoking: SDS++ Compiler'
sds++ -DPLATFORM_ZCU102 -DHLS_NO_XIL_FPO_LIB -DWITH_SDSOC -DSAMPLE_OPTICAL_FLOW -DOF_PIX_PER_CLOCK=2 -Wall -O3 -I"../src" -I"../src/include" -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -c -fmessage-length=0 -MT"src/optical_flow.o" -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/aarch64-xilinx-linux -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/backward -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/glib-2.0 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/lib/glib-2.0/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -MMD -MP -MF"src/optical_flow.d" -MT"src/optical_flow.o" -o "src/optical_flow.o" "../src/optical_flow.cpp" -sds-hw read_optflow_input optical_flow_wrap.cpp  -clkid 2 -sds-end -sds-hw "xFDenseNonPyrLKOpticalFlow<25,0,2160,3840,2>" optical_flow_wrap.cpp  -files ../src/include/imgproc/xf_dense_npyr_optical_flow.hpp  -clkid 2 -sds-end -sds-hw write_optflow_output optical_flow_wrap.cpp  -clkid 2 -sds-end -sds-sys-config linux -sds-proc a53_0 -sds-pf "C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION"
Create data motion intermediate representation
C:\Users\Miloslav\Projects\SDSoC\OF2_Cust\Release>C:\Xilinx\SDx\2017.1\llvm-clang\win64\llvm\bin\clang.exe -I../src -I../src/include -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/aarch64-xilinx-linux -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/backward -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/glib-2.0 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/lib/glib-2.0/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -DPLATFORM_ZCU102 -DHLS_NO_XIL_FPO_LIB -DWITH_SDSOC -DSAMPLE_OPTICAL_FLOW -DOF_PIX_PER_CLOCK=2 -Wall -fmessage-length=0 -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -MMD -MP -D __SDSCC__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -I C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -I C:/Xilinx/SDx/2017.1/target/aarch64-linux/include -I C:/Xilinx/SDx/2017.1/Vivado_HLS/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 -emit-llvm -S C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow.cpp -o C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/.llvm/src/optical_flow.s
C:\Users\Miloslav\Projects\SDSoC\OF2_Cust\Release>exit /b 0
Compiling C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow.cpp
                 from C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow_int.h:47,
                 from C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow.cpp:44:
sds++ log file saved as C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/reports/sds_optical_flow.log
'Finished building: ../src/optical_flow.cpp'
'Building file: ../src/optical_flow_wrap.cpp'
sds++ -DPLATFORM_ZCU102 -DHLS_NO_XIL_FPO_LIB -DWITH_SDSOC -DSAMPLE_OPTICAL_FLOW -DOF_PIX_PER_CLOCK=2 -Wall -O3 -I"../src" -I"../src/include" -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -c -fmessage-length=0 -MT"src/optical_flow_wrap.o" -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/aarch64-xilinx-linux -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/backward -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/glib-2.0 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/lib/glib-2.0/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -MMD -MP -MF"src/optical_flow_wrap.d" -MT"src/optical_flow_wrap.o" -o "src/optical_flow_wrap.o" "../src/optical_flow_wrap.cpp" -sds-hw read_optflow_input optical_flow_wrap.cpp  -clkid 2 -sds-end -sds-hw "xFDenseNonPyrLKOpticalFlow<25,0,2160,3840,2>" optical_flow_wrap.cpp  -files ../src/include/imgproc/xf_dense_npyr_optical_flow.hpp  -clkid 2 -sds-end -sds-hw write_optflow_output optical_flow_wrap.cpp  -clkid 2 -sds-end -sds-sys-config linux -sds-proc a53_0 -sds-pf "C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION"
Processing -sds-hw block for read_optflow_input
Processing -sds-hw block for xFDenseNonPyrLKOpticalFlow<25,0,2160,3840,2>
Processing -sds-hw block for write_optflow_output
C:\Users\Miloslav\Projects\SDSoC\OF2_Cust\Release>C:\Xilinx\SDx\2017.1\llvm-clang\win64\llvm\bin\clang.exe -I../src -I../src/include -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/aarch64-xilinx-linux -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/c++/6.2.1/backward -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/include/glib-2.0 -IC:\Users\Miloslav\Projects\ZCU102\zcu102_es2_reVISION\sw\aarch64-linux-gnu\sysroot/usr/lib/glib-2.0/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -DPLATFORM_ZCU102 -DHLS_NO_XIL_FPO_LIB -DWITH_SDSOC -DSAMPLE_OPTICAL_FLOW -DOF_PIX_PER_CLOCK=2 -Wall -fmessage-length=0 -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -MMD -MP -D __SDSCC__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -I C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -I C:/Xilinx/SDx/2017.1/target/aarch64-linux/include -I C:/Xilinx/SDx/2017.1/Vivado_HLS/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 -emit-llvm -S C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow_wrap.cpp -o C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/.llvm/src/optical_flow_wrap.s
Performing accelerator source linting for read_optflow_input
INFO: [Linting 83-3001] read_optflow_input
Performing accelerator source linting for w1_xFDenseNonPyrLKOpticalFlow
INFO: [Linting 83-3001] xFDenseNonPyrLKOpticalFlow<25,0,2160,3840,2>
Performing accelerator source linting for write_optflow_output
INFO: [Linting 83-3001] write_optflow_output
Performing pragma generation
C:\Users\Miloslav\Projects\SDSoC\OF2_Cust\Release>C:\Xilinx\SDx\2017.1\llvm-clang\win64\llvm\bin\clang.exe -E -IC:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src -IC:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/include -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/include/c++/6.2.1 -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/include/c++/6.2.1/aarch64-xilinx-linux -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/include/c++/6.2.1/backward -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/include -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/include/glib-2.0 -IC:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/sysroot/usr/lib/glib-2.0/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -DPLATFORM_ZCU102 -DHLS_NO_XIL_FPO_LIB -DWITH_SDSOC -DSAMPLE_OPTICAL_FLOW -DOF_PIX_PER_CLOCK=2 -Wall -fmessage-length=0 -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -MMD -MP -D __SDSCC__ -m64 -I C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -I C:/Xilinx/SDx/2017.1/target/aarch64-linux/include -IC:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src -D __SDSVHLS__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -w -I C:/Users/Miloslav/Projects/ZCU102/zcu102_es2_reVISION/sw/aarch64-linux-gnu/video_lib/include -I C:/Xilinx/SDx/2017.1/target/aarch64-linux/include -I C:/Xilinx/SDx/2017.1/Vivado_HLS/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -IC:/Xilinx/SDx/2017.1/SDK/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/src/optical_flow_wrap.cpp -o C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/optical_flow_wrap_pp.cpp
INFO: [PragmaGen 83-3231] Successfully generated tcl script: C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/read_optflow_input.tcl
Moving function read_optflow_input to Programmable Logic
INFO: [PragmaGen 83-3231] Successfully generated tcl script: C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/w1_xFDenseNonPyrLKOpticalFlow.tcl
Moving function w1_xFDenseNonPyrLKOpticalFlow to Programmable Logic
ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for w1_xFDenseNonPyrLKOpticalFlow C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/w1_xFDenseNonPyrLKOpticalFlow/solution/impl/ip. For possible causes, review C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/w1_xFDenseNonPyrLKOpticalFlow/solution/solution.log or C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/vivado_hls.log.
C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/vhls/vivado_hls.log (last 20 lines):
INFO: [XFORM 203-102] Partitioning array 'lb2.data.6' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.7' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.8' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.9' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.10' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.11' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.12' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.13' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.14' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.15' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.16' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.17' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.18' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.19' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.20' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.21' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.22' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.23' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.24' in dimension 2 automatically.
INFO: [XFORM 203-102] Partitioning array 'lb2.data.25' in dimension 2 automatically.
sds++ log file saved as C:/Users/Miloslav/Projects/SDSoC/OF2_Cust/Release/_sds/reports/sds_optical_flow_wrap.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/optical_flow_wrap.o] Error 1
12:30:35 Build Finished (took 4m:23s.409ms)
Tags (3)
Appearently, re-running the project after cleaning is the only solution as mentioned in the guide:
http://www.wiki.xilinx.com/x8%20Other%20Information-8.1%20Known%20Issues
8 Other Information
8.1 Known Issues
  • SDSoC accelerator code runs very slowly in pure software implementation when Debug configuration is used.
    Solution: Set project build configurations to Release which sets sdsoc compiler to optimize most (-O3).
  • When building the optical_flow sample app, you will see a number of warnings, such as: "WARNING: [SDSoC 0-0] No size pragma specified for pointer argument f0Stream".
    Solution: These can be ignored.
  • SDSoC reports the design did no meet timing constraints when running under Windows.
    Solution: Clean the project and build it again.
I took the solution file created by SDS and opened it in HLS.
Interrestingly, the C Synthesis did the same thing and stopped at the same level.
Without touching ANYTHING, ABSOLUTELY ANYTHING, the synthesis finished correctly and I think I can generate the IP.
This is the result from HLS.
8 Other Information
8.1 Known Issues
