bogdan.deac
SDSoC FPGA Resource Utilization
How can I obtain an FPGA used resources report from SDSoC (how many LUTs, FFs, etc. were used in total) ?
Bogdan D.
kenkovaa
One way of analyzing the design is to open the design checkpoint and generate from there utilization reports in Vivado. To do that you can open the dcp in Vivado: "open_checkpoint C:/<workspace>/<appname>/Debug/_sds/p0/_vpl/ipi/imp/imp.runs/impl_1/zed_wrapper_routed.dcp" and then just switch to Default layout and issue "report_utilization -name foo" for example.
--Kim
kenkovaa
--Kim
tanders
The Performance Estimate Report will give you a rough idea quickly.
The HLS Report, generated for each Hardware Function will give estimates per Function/Accelerator.
The vivado project: <project>/<config>/_sds/p0/vivado/prj/prj.xpr should give you complete view (e.g. utilization in the project summary), after a hardware build.
