SDSoC + ZCU102
I run lab6 of the SDSoC intro tutorial on ZCU102, but I got an error "bitstream is not compatible with the target revision".
Anyone can help me solve this problem.
Additionally, I run lab1 successfully via Standalone not linux.
Chase
Re: SDSoC + ZCU102
check the target device of your project and board target device. You may not be able to force ES1 bitstream to ES2. This is the reason you are seeing an error which programming the HW.
2016.3 PetaLinux Supports the ZCU102 board with ES2 silicon and rev 1.0 of the BSP - You can download the BSP from the below link.
https://www.xilinx.com/support/answers/68145.html
Thanks and Regards
Balkrishan
Re: SDSoC + ZCU102
Thanks and Regards
Balkrishan
Re: SDSoC + ZCU102
I have updated the SDSoC to 2016.4 and choose the ES2 then the problem solved。
But I still can not boot the linux from SD card, the error shows "firmware registration failed".
Thanks again,
Chase
Re: SDSoC + ZCU102
I am also getting the error "bitstream is not compatible with the target revision, use -no-revision-check to allow programming.  How do I go about this using SDK?  I am using 2017.2.1.
I have attached a snapshot of the error.
Re: SDSoC + ZCU102
Currently there is no way to use this option (-no-revision) in the GUI. You will need to program the PL from the XSCT (Xilinx Tools -> XSCT console)
For example:
connect
fpga -no-rev -f system-top.bit
Re: SDSoC + ZCU102
Hello
     I use the ZCU102 to do the lab2 in ug1028-sdsoc-intro-tutorial.pdf . There is a error said 'bitstream is not compatible with the target revision, use -no-revision-check to allow programming'. I know the reason is my board is a ES version.  In vivado I know I could print 'set_param com.use_bitstream_version_check false'.But how and where I can use -no-revision-check. I use the SDSoc 2018.2 .
Thanks a lot.
