pietro_dcs
SDSoC for zedboard
Gooe morning
Where do I get the SDSoC for the ZedBoard??
Thank You
pietro_dcs
I mean if there exists a free locked license of SDSoC for the zedboard..
Thank You
stephenm
SDSoC can be downloaded from here:
https://www.xilinx.com/products/design-tools/software-zone.html
However, SDSoC has been replaced by Vitis. So, if you are starting a new project, I recommend you use Vitis
pietro_dcs
Thank you for the support.
I just installed vitis. I am fighting to understand how to work wiith the SDSoC.
The interface has not a direct access to vitis. Just point me a tutorial finalized to work with the SDSoC.
Is the web license inclusive for the SDSoC also?
Or is another license needed ?
Thank You
Pietro
pietro_dcs
Good morning
I installed the VITIS. I see the normal flow for generating the platform and open the VITIS SDK.
And where is the SDSoC?
Please I need the right tutorial...
Thank You
Pietro
stephenm
As I mentioned in my previous reply. Vitis has replaced SDSoC. So, you can either use SDSoC, or Vitis.
Vitis is a unified tool; so SDSoC + SDAccel. Vitis supports zynq 7000.
Some resources to get you started:
https://github.com/Xilinx/Vitis-In-Depth-Tutorial
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Creating-an-Acceleration-Platform-for-Vitis-Part-One-Creating/ba-p/1138208
pietro_dcs
Good morning
I am grateful for the assistance. I am trying to have the clue on the important point I have to analyze.
Can You point me direct on a working example centered on a bare metal design, with the
c source code function accelerated in the PL.
I would be great
Thank You
Pietro
pietro_dcs
Hi all of
I see it is difficult to explain what is my side of the problem.
I will try to fit with what I have.
I see the videos of Nikos Petrellis are the best fitting for me. Still when I do the same things he does on the video I get different effects.
Mah
It is closed ,,,
Thank You
Pietro
