07-28-2019 03:27 AM
Hello.
i am doing the custom platform generation in the Vivado tool. After completing the exporting and entire process of the platform generation i am etting error while generating the DSA file for the same. Attaching files and screenshot of the same.
07-28-2019 11:44 PM
hi @meet.bais
Attachments are missing.
Please upload them again.
07-29-2019 12:58 AM
i am unable to attach the project files.
07-29-2019 01:51 AM
Hi @meet.bais
Is it possible to take the screenshot of error or just copy paste the error log here?
07-30-2019 12:55 AM
here is the error log
open_project C:/Users/Meet/Xilinx_projects/zybo7/zybo7.xpr
write_dsa -force ./zybo7.dsa
INFO: [Vivado 12-4895] Creating DSA: ./zybo7.dsa ...
CRITICAL WARNING: [Project 1-655] Project does not have Board Part set. Board related data may be missing or incomplete in the generated DSA.
WARNING: [Project 1-646] Board name, vendor and part not set in DSA.
WARNING: [Project 1-645] Board images not set in DSA.
CRITICAL WARNING: [Vivado 12-7009] BD 'zybo' is not in validated state. Please validate and re-generate the BD prior to generating a DSA. The BD can be validated in the GUI or by using Tcl command validate_bd_design in the Tcl console.
ERROR: [SDSoC-pfm-18] sdsoc::pfm_clock - clock domain 'zybo_processing_system7_0_0_FCLK_CLK0' for proc_sys_reset instance 'proc_sys_reset_0' does not match clock domain '/clk_wiz_0_clk_out1' for clock '/clk_wiz_0/clk_out1'
ERROR: [SDSoC-pfm-100] Incorrect 'clk_out1' value for the PFM.CLOCK of '/clk_wiz_0'
ERROR: [SDSoC-pfm-18] sdsoc::pfm_clock - clock domain 'zybo_processing_system7_0_0_FCLK_CLK0' for proc_sys_reset instance 'proc_sys_reset_1' does not match clock domain '/clk_wiz_0_clk_out1' for clock '/clk_wiz_0/clk_out2'
ERROR: [SDSoC-pfm-100] Incorrect 'clk_out2' value for the PFM.CLOCK of '/clk_wiz_0'
ERROR: [SDSoC-pfm-18] sdsoc::pfm_clock - clock domain 'zybo_processing_system7_0_0_FCLK_CLK0' for proc_sys_reset instance 'proc_sys_reset_2' does not match clock domain '/clk_wiz_0_clk_out1' for clock '/clk_wiz_0/clk_out3'
ERROR: [SDSoC-pfm-100] Incorrect 'clk_out3' value for the PFM.CLOCK of '/clk_wiz_0'
ERROR: [SDSoC-pfm-18] sdsoc::pfm_clock - clock domain 'zybo_processing_system7_0_0_FCLK_CLK0' for proc_sys_reset instance 'proc_sys_reset_3' does not match clock domain '/clk_wiz_0_clk_out1' for clock '/clk_wiz_0/clk_out4'
ERROR: [SDSoC-pfm-100] Incorrect 'clk_out4' value for the PFM.CLOCK of '/clk_wiz_0'
ERROR: [Vivado 12-5878] Failed to generate hpfm file for BD File: C:/Users/Meet/Xilinx_projects/zybo7/zybo7.srcs/sources_1/bd/zybo/zybo.bd
ERROR: [Common 17-53] User Exception: Unable to get hpfm file from project property dsa.hpfm_file or from the BD itself.
update_compile_order -fileset sources_1
07-30-2019 12:57 AM
Here is the error log
08-15-2019 11:07 PM
Hi @meet.bais
Looks like the BD is not valid.
Please validate and then generate bitstream
