SDSoC timing error
SDSoC seems to treat timing errors as failure and exits. Is there a way to demote timing error to critical warning so that SDSoc can successfully generate bitstream?
Thanks. Regards,
  Mariano
Re: SDSoC timing error
Hi @mariano_severi,
There is a way to fix the timing violations.
You can use -xp params as mentioned below,
For implementation:
sds++ -xp "vivado_prop:run.impl_1.{STEPS.OPT_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}"
For Synthesis:
sds++ -xp “vivado_prop:run.synth_1.{STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS}={-directive AreaOptimized_high}”
 You can refer,
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/uno1528577884586.html?hl=synthesis
Best Regards,
Nutan
Hi @mariano_severi,
For implementation:
For Synthesis:
 You can refer,
Best Regards,
Nutan
Hi @mariano_severi
Also,
To force sds++ to skip the timing violation check and continue, allowing you to proceed and correct timing issues later, you can use this parameter: param:compiler.skipTimingCheckAndFrequency Scaling=1
Best Regards,
Nutan
Hi @mariano_severi
Is your timing issue resolved?
Best Regards,
Nutan
