SDSoC(ver 2016.4): pragma_gen.exe has stopped working...
Hi.
I'm trying to build a design on SDSoC 2016.4.
However, I got the error "pragma_gen.exe has stopped working".
Does anyone know possible cases for that?
Although I tried the same design (same HW function) in Vivado HLS, there is no error.
Thank you in advance.
This bug was reported in 2016.4 SDSoC tools. SDSoC fails to compile C structs. Please upgrade to 2017.1 SDx to prevent this failure.
Please mark an answer "Accept as solution" if a post has the solution to your issue.
Please provide more info:
1. Operating system (windows7, 8, 10,...)
2. Sample code that causes the problem
3. Log file from the build
Thanks!
Sam
Thank you for your reply!
  windows 7 64bit
The below is top function (HW function).
#include <stdio.h>
~~some include files~~~
    typedef struct {
        int      A;
        float   B;
    } Struct2;
    typedef struct {
        int         N;
        Struct2  Array[5];
    } Struct1;
    void HW_Acceralator(
        short     array1[10],
        short     array2[10],
        int         var1,
        int         var2
        Struct1  *Stu1
        short     AR1[10];
        short     AR2[10];
        short     AR3[10];
        Struct1  Stu_tmp;
        Func1( array1, AR1 );
        Func1( array2, AR2 );
        Func2( AR3, AR1, AR2, var1, var2, &Stu_tmp );
        *Stu1 = Stu_tmp;
        return;
E:\Projects\SDSoC\Sample\Debug>exit /b 0
pragma_gen -func HW_Acceralator -tcl E:/Projects/SDSoC/Sample/Debug/_sds/vhls/HW_Acceralator.tcl E:/Projects/SDSoC/Sample/Debug/_sds/vhls/HW_Acceralator_pp.c -multi_aximm -- -c -D __SDSVHLS__ -IE:/Projects/SDSoC/Sample/src -Wall -O0 -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -m32 -I C:/Xilinx/SDx/2016.4/aarch32-linux/include -IE:/Projects/SDSoC/Sample/src/subfunc -target arm-linux-gnueabihf -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -O0 -g -w -I C:/Xilinx/SDx/2016.4/aarch32-linux/include -I C:/Xilinx/SDx/2016.4/Vivado_HLS/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/5.2.1/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/5.2.1/include-fixed -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include
ERROR: [SDSoC 0-0] Exiting sdscc : Error when calling 'pragma_gen -func HW_Acceralator -tcl E:/Projects/SDSoC/Sample/Debug/_sds/vhls/HW_Acceralator.tcl E:/Projects/SDSoC/Sample/Debug/_sds/vhls/HW_Acceralator_pp.c -multi_aximm -- -c -D __SDSVHLS__ -IE:/Projects/SDSoC/Sample/src -Wall -O0 -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -m32 -I C:/Xilinx/SDx/2016.4/aarch32-linux/include -IE:/Projects/SDSoC/Sample/src/subfunc -target arm-linux-gnueabihf -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -O0 -g -w -I C:/Xilinx/SDx/2016.4/aarch32-linux/include -I C:/Xilinx/SDx/2016.4/Vivado_HLS/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/5.2.1/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/lib/gcc/arm-linux-gnueabihf/5.2.1/include-fixed -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include -IC:/Xilinx/SDx/2016.4/SDK/gnu/aarch32/nt/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include'
sdscc log file saved as E:/Projects/SDSoC/Sample/Debug/_sds/reports/sds_HW_Acceralator.log
ERROR: [SDSoC 0-0] Build failed
sdscc completed at Fri Nov 10 10:47:13 +0900 2017
Thank you for your cooperation.
