haojie1588
SDSoC
when i start sdx, there are some errors in SDx Log, it displays that can not find samples directory in SDx install location and can not find Manifest file in SDx install location. How can I solve this problem. Thanks.2019-12-02 17-15-55屏幕截图.png
nutang
Hi @haojie1588
Please let me know version details and also host OS
Best Regards,
Nutan
haojie1588
Hi.@nutang
thank you for your reply. The SDSoC is 2018.3 version and host OS is ubuntu 16.04 LTS.
nutang
Hi @haojie1588
It looks like the installation issue.
Can you see the Samples folder in your installation path?
Best Regards,
Nutan
haojie1588
I don't know if this is an installation issue, but I can create a SDx application and build normally.
And I can find the Samples folder in my installation path. 2019-12-04 22-19-23屏幕截图.png
