SDaccel 2018.2.xdf: Incorrect AXI4-lite Mapping in generated xclbin
Hi!
I'm using SDAccel Manual flow (based on rtl_adder_pipes example).
In my case, I use 3 IPs connected using pipes, with each IP having an AXI4-lite interface
The synthesis runs smoothly (no ERROR or CRITICAL WARNING except the usual ones) but I can see that there is an issue in the generated xclbin file.
In the XML part, there is a description of each IP with their respective remapped addresses on the AXI4-lite bus.
Those addresses are empty for 2 of my IPs as shown in the attached screenshot.
However if I take a look a the file "_x/link/vivado/output/address_map.xml" the addresses are correctly inferred.
Moreover, if I test my design on Alveo U200 using the addresses from the "addres_map.xml" file it works perfectly.
Something wrong in the xclbin file generation?
@kmorris ,
SDAccel 2019.1 failed at a very early stage pointing out the issue (kernel naming typo in xml file)
After fixing it, the xclbin file generated is now correct.
Hi @gdufourcq, would it be possible for you to test your design using 2018.3? There have been improvements in this area that hopefully corrects what you are seeing in the xclbin file.
Please don’t forget to reply, kudo, and accept as solution!
I've just tested with 2018.3 and it shows the exact same issue
Thank you for confirming that. Would you be able to send/attach your modified files from the rtl_adder_pipes example so we can replicate and examine the issue?
How can I share the project directly to you?
It contains sensitive data that I can't publish on such forum.
I have sent you an EZMove email message from which you can upload the files directly to me. Let me know if you have any issues using it.
Hi @gdufourcq, I have reviewed the files you provided and I do get the same results you reported. I do see that in your userip .xml files, there are no arguments defined within the <arg> tags. I wanted to clarify if it is intended for your userip to have no arguments?
Hi @kmorris,
Indeed my "user_ip" kernels have no arguments.
They are pure-RTL kernels that need only the pipe connection to the "drm" kernel.
FYI, I'm currently synthesizing on 2019.1 to see if the problem stills.
I'll keep you posted
@kmorris ,
