SDx & xfopencv: head file not found
OS: ubuntu16.04.3 LTS 64bit
Software: SDSoC 2016.4
Hardware: ZYBO-Z7
I have met this problem when compiling xfopencv's example projects. I followed the non-reVISON configuration steps showed by ug1233. After adding /xxx/xfopencv/include folder to the directories, I didn't see any change on Project Explorer view. And the editor shows error: 'Unsolved include: common/xf_common.h'
For example, the example project 'accumulate' has been imported in src folder. Errors orrurred when I try to build the project.
/xxx/test/src/accumulate/xf_accumulate_config.h:37:10: fatal error: 'common/xf_common.h' file not found
#include "common/xf_common.h"
ERROR: [SDSoC 0-0] clang exited with non-zero code processing /xxx/test/src/accumulate/xf_accumulate_image_accel.cpp
sds++ log file saved as ./test/Release/_sds/reports/sds_xf_accumulate_image_accel.log
ERROR: [SDSoC 0-0] Build failed
make: *** [src/accumulate/xf_accumulate_image_accel.o] Error 1
src/accumulate/subdir.mk:21: recipe for target 'src/accumulate/xf_accumulate_image_accel.o' failed
Re: SDx & xfopencv: head file not found
Hi @seulsj
A very important note is,
The OpenCV library is not provided by Xilinx for custom platforms. You are required to provide the library. Use the reVISION platform in order to use the OpenCV library provided by Xilinx.
Best Regards,
Nutan
Hi @seulsj
Best Regards,
Nutan
You also need to make sure that <xfopencv>/include folder is in the Includes section of C/C++ Build settings. Right click on the project, select C/C++ Build settings, SDS++ compiler, Directories. Add <xfoepncv>/include/ folder to the list.
