samoaibo
Segmentation fault when using Xil_In32()
I created a platform project in Vitis based on a project from Vivado. Then I created a linux application project based on this platform. I need to read and write to the address space of PL. When I try to read the value from address space of PL using Xil_In32(), an error "Segmentation fault" is returned. It worked fine in the standalone app.
Vitis created BOOT.BIN using *.bit.
Please help me
stephenm
dgisselq
@samoaibo,
Did you use Xil32_Out() on the raw address space (which goes through the virtual to physical memory map), or on the /dev/mem file (which does not)?
Dan
samoaibo
I specified the physical address from Vivado and hoped that everything would work as in the standalone application. I am probably wrong and need to convert a physical address to a virtual address?
Does bitstream load into an fpga if loaded from an sd card?
stephenm
