viggy
Setting a breakpoint in Vitis
I'm trying to debug a bare metal application running on a 4 core MicroBlaze design. I set a breakpoint in my source code (in Vitis), but when I launch the debugger, the breakpoint changes to a warning, with "Line breakpoint: helloworld.cpp [line: 138] failed to plant: End of file"
What does this mean, and why can't I step through my code?
Thanks!
Viggy
florentw
HI @viggy
This is probably because your code (and this particular line) is getting optimized by the compiler. You can try to change the optimization level to prevent optimizations
Florent
viggy
Hmm, I found that if I comment out this section of code, setting breakpoints suddenly works:
u32 uart_tx_empty = 0;
while (uart_tx_empty != 1) {
// Note: sleeping for 0.2 seconds would be better...
// Note: sleep doesn't work on MB it messes up the debugger
// https://forums.xilinx.com/t5/Embedded-Development-Tools/microblaze-sleep/td-p/47196
//sleep(0.25);
 uart_tx_empty = (Xil_In32(ADDR_UART_STAT) >> 2) & 1;
Viggy
