stzog
Software emulation of compute unit(s) exited unexpectedly
Hi to all!
Based on hello world example i created a sobel edge detection  project with 3 kernels that i call in host.
The build is ok but in sw emulation run i get the following.
INFO: [SW-EM 09-0] Unable to find emconfig.json. Using default device.
Found Platform
Platform Name: Xilinx
INFO: Reading ./binary_container_1.xclbin
Loading: './binary_container_1.xclbin'
Trying to program device[0]: xilinx_zcu102_base_202010_1
Device[0]: program successful!
My host code is...
#include "xcl2.hpp"
#include <stdio.h>
#include <algorithm>
#include <iostream>
#include<stdlib.h>
#include <vector>
#include <errno.h>
#include <math.h>
#include <string.h>
#include "Image.h"
#define DATA_SIZE 4096
int size = DATA_SIZE;
int main(int argc, char **argv) {
    if (argc != 2) {
        std::cout << "Usage: " << argv[0] << " <XCLBIN File>" << std::endl;
        return EXIT_FAILURE;
    std::string binaryFile = argv[1];
    size_t vector_size_bytes = sizeof(int) * DATA_SIZE;
    cl_int err;
    cl::Context context;
    cl::Program program;
    cl::Kernel krnl_sob;
    cl::Kernel krnl_sob1;
    cl::Kernel krnl_sob2;
    cl::CommandQueue q;
      std::vector<unsigned char, aligned_allocator<unsigned char>> source_in1(DATA_SIZE);
      std::vector<unsigned char, aligned_allocator<unsigned char>> source_in2(DATA_SIZE);
      std::vector<unsigned char, aligned_allocator<unsigned char>> source_sw_results(DATA_SIZE);
      std::vector<unsigned char, aligned_allocator<unsigned char>> source_sw_results2(DATA_SIZE);
      std::vector<unsigned char, aligned_allocator<unsigned char>> source_sw_results3(DATA_SIZE);
     for (int i = 0; i < DATA_SIZE; i++) {
         source_sw_results[i] = source_in1[i];
    auto devices = xcl::get_xil_devices();
    auto fileBuf = xcl::read_binary_file(binaryFile);
    cl::Program::Binaries bins{{fileBuf.data(), fileBuf.size()}};
    int valid_device = 0;
    for (unsigned int i = 0; i < devices.size(); i++) {
        auto device = devices[i];
        // Creating Context and Command Queue for selected Device
        OCL_CHECK(err, context = cl::Context(device, NULL, NULL, NULL, &err));
        OCL_CHECK(err,
                  q = cl::CommandQueue(
                      context, device, CL_QUEUE_PROFILING_ENABLE, &err));
        std::cout << "Trying to program device[" << i
                  << "]: " << device.getInfo<CL_DEVICE_NAME>() << std::endl;
        cl::Program program(context, {device}, bins, NULL, &err);
        if (err != CL_SUCCESS) {
            std::cout << "Failed to program device[" << i
                      << "] with xclbin file!\n";
        } else {
            std::cout << "Device[" << i << "]: program successful!\n";
            OCL_CHECK(err, krnl_sob = cl::Kernel(program, "grayconvert", &err));
            OCL_CHECK(err, krnl_sob1=cl::Kernel(program, "imgscan", &err));
            OCL_CHECK(err, krnl_sob1=cl::Kernel(program, "borderscan", &err));
            valid_device++;
            break; // we break because we found a valid device
    if (valid_device == 0) {
        std::cout << "Failed to program any device found, exit!\n";
        exit(EXIT_FAILURE);
    source_in1={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16};
    // Allocate Buffer in Global Memory
  // Buffers are allocated using CL_MEM_USE_HOST_PTR for efficient memory and
  // Device-to-host communication
  OCL_CHECK(err, cl::Buffer buffer_in1(
                     context, CL_MEM_USE_HOST_PTR | CL_MEM_READ_ONLY,
                     vector_size_bytes, source_in1.data(), &err));
  OCL_CHECK(err, cl::Buffer buffer_output(
                     context, CL_MEM_USE_HOST_PTR | CL_MEM_WRITE_ONLY,
  OCL_CHECK(err, err = krnl_sob.setArg(0, buffer_in1));
  //OCL_CHECK(err, err = krnl_sob.setArg(1, buffer_in2));
  OCL_CHECK(err, err = krnl_sob.setArg(1, buffer_output));
  OCL_CHECK(err, err = krnl_sob.setArg(2, size));
OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_in1},
                                                  0 /* 0 means from host*/));
// Launch the Kernel
  // to always use enqueueTask() for invoking HLS kernel
  OCL_CHECK(err, err = q.enqueueTask(krnl_sob));
  // Copy Result from Device Global Memory to Host Local Memory
  OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_output},
                                                  CL_MIGRATE_MEM_OBJECT_HOST));
  q.finish();
  // Creating  Kernel Object and setting args
  OCL_CHECK(err, cl::Buffer buffer_in2(
                       vector_size_bytes, source_sw_results.data(), &err));
    OCL_CHECK(err, cl::Buffer buffer_output2(
                       vector_size_bytes, source_sw_results2.data(), &err));
  //cl::Kernel krnl_sob1(program, "imgscan");
  OCL_CHECK(err, err = krnl_sob1.setArg(0, buffer_in2));
  OCL_CHECK(err, err = krnl_sob1.setArg(1, buffer_output2));
  OCL_CHECK(err, err = krnl_sob1.setArg(2, size));
OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_in2},
    OCL_CHECK(err, err = q.enqueueTask(krnl_sob1));
  OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_output2},
  q.finish();
 //OCL_CHECK(err, cl::Kernel krnl_sob2(program, "borderscan", &err));
  OCL_CHECK(err, cl::Buffer buffer_in3(
    OCL_CHECK(err, cl::Buffer buffer_output3(
                       vector_size_bytes, source_sw_results3.data(), &err));
//int size = DATA_SIZE;
  OCL_CHECK(err, err = krnl_sob2.setArg(0, buffer_in3));
  OCL_CHECK(err, err = krnl_sob2.setArg(1, buffer_output3));
  OCL_CHECK(err, err = krnl_sob2.setArg(2, size));
OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_in3},
    OCL_CHECK(err, err = q.enqueueTask(krnl_sob2));
  OCL_CHECK(err, err = q.enqueueMigrateMemObjects({buffer_output3},
  q.finish();
    bool match = true;
    std::cout << "TEST " << (match ? "PASSED" : "FAILED") << std::endl;
    return (match ? EXIT_SUCCESS : EXIT_FAILURE);
Thanks in advance for any piece of advice!
graces
I noticed this message.
How did you launch sw_emu? If from command line mode, you need to run 'emconfigutil' command to generate emulation configuration file emconfig.json for the target platform. The emconfig.json file must be in the same directory as the host executable.
stzog
@graces
Hi!
I use Vitis GUI to build and run sw emulation,not command line mode.
How to do this via GUI?
stzog
@graces
Is this error crucial for sw emulation run?
Moreover in my project the emconfig.json file exists on Emulation-SW folder.
