jsyoo1117
Source file is a directory: /home/myname/workspace/ip_cache
while trying to compile a project in SDAccel I get the following error. The makefile was machine-generated. I tried deleting the ip_cache directory both from the makefile and the actual disk, but neither worked(kept reappearing in the makefile and got stuck when deleting from disk) Can someone help me out? I'm using 2018.2 on Ubuntu 16.04.6. I guess emptying the cache might  help, but that post was for Vivado, and I can't find the equivalents in SDAccel.
ERROR: [XOCC 60-603] Source file is a directory: /home/myname/workspace/ip_cache
ERROR: [XOCC 60-623] Unsupported input file type specified.
makefile:77: recipe for target 'binary_container_1.xclbin' failed
make: *** [binary_container_1.xclbin] Error 1
This is the makefile of the primary build part
.PHONY: all clean
all: $(BINARY_CONTAINERS) $(HOST_EXE)
.NOTPARALLEL: clean
clean:
-$(RM) $(BINARY_CONTAINERS) $(ALL_KERNEL_OBJS) $(ALL_MESSAGE_FILES) $(HOST_EXE) $(HOST_OBJECTS)
-$(RM) *.xclbin.sh
-$(RMDIR) $(BUILD_SUBDIRS)
-$(RMDIR) _xocc*
-$(RMDIR) .Xil
.PHONY: incremental
incremental: all
nothing:
# binary container: binary_container_1.xclbin
binary_container_1/krnl_vadd.xo: ../src/krnl_vadd.cl
@mkdir -p $(@D)
-@$(RM) $@
$(XOCC) $(XOCC_OPTS) -c -k krnl_vadd --nk krnl_vadd:1:krnl_vadd_1 --messageDb $(subst .xo,.mdb,$@) -I"$(<D)" --xp misc:solution_name=krnl_vadd --temp_dir binary_container_1 --report_dir binary_container_1/reports --log_dir binary_container_1/logs -o"$@" "$<"
binary_container_1.xclbin: $(BINARY_CONTAINER_1_OBJS)
-@echo $(XOCC) $(XOCC_OPTS) -l --nk krnl_vadd:1:krnl_vadd_1 --messageDb $(subst .xclbin,.mdb,$@) --xp misc:solution_name=link --temp_dir binary_container_1 --report_dir binary_container_1/reports --log_dir binary_container_1/logs --profile_kernel --remote_ip_cache /home/myname/workspace/ip_cache -o"$@" $(+) > binary_container_1.xclbin.sh
hongh
Hi, @jsyoo1117 ,
SDAccel will just call Vivado, so the "set_param" method for clean IP cache will still work.
Using the --xp XOCC compiler switch can help to pass the paramter.
jsyoo1117
Sorry, solved the problem myself. I don't know why, but creating the project directory right under workspace caused the problem. Creating a subdirectory, such as ~/workspace/test/myproject solved the problem beautifully. Not deleting this post for future demand.
hongh
Hi, @jsyoo1117 ,
jsyoo1117
@hongh wrote:
Hi, @jsyoo1117 ,
Well that was obvious... Thx for the comment!
