Support for arbitrary precision floating point types in SDSOC
I want to use half data type (FP16) from hls_half.h. When I compile my code in Vivado HLS 2016.4, the code is complied, but, when I copy the same code to SDSoC 2016.4 and mark the function for hardware implementation, I get the following error
INFO: [SDSoC 0-0] Link application ELF file
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `half::xip_fpo_get_data(__xip_fpo_struct*) const':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1086: undefined reference to `xip_fpo_set_zero'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1089: undefined reference to `xip_fpo_set_inf'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1092: undefined reference to `xip_fpo_set_nan'
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `half::xip_fpo_half_get_flt() const':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1100: undefined reference to `xip_fpo_init2'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1110: undefined reference to `xip_fpo_get_flt'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1112: undefined reference to `xip_fpo_clear'
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `half::xip_fpo_half_set_flt(float)':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1138: undefined reference to `xip_fpo_init2'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1139: undefined reference to `xip_fpo_set_flt'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:1141: undefined reference to `xip_fpo_clear'
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `detail::enable<detail::expr, half, half, void>::type detail::operator+<half, half>(half, half)':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:2173: undefined reference to `xip_fpo_add'
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `detail::enable<detail::expr, half, half, void>::type detail::operator*<half, half>(half, half)':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:2175: undefined reference to `xip_fpo_mul'
C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o: In function `half detail::binary_operator<int (*)(__xip_fpo_struct*, __xip_fpo_struct const*, __xip_fpo_struct const*)>(int (*)(__xip_fpo_struct*, __xip_fpo_struct const*, __xip_fpo_struct const*), half, half)':
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:2164: undefined reference to `xip_fpo_inits2'
C:/Xilinx/SDx/2016.4/Vivado_HLS/include/hls_half.h:2169: undefined reference to `xip_fpo_clears'
collect2.exe: error: ld returned 1 exit status
ERROR: [SDSoC 0-0] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++ C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.o C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/TestConv10.o -L C:/Xilinx/SDx/2016.4/aarch32-linux/lib -LC:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs -Wl,--start-group -Wl,--end-group -Wl,--start-group -lpthread -lsds_lib -lxlnk_stub -Wl,--end-group -o C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/swstubs/Conv10.elf'
sds++ log file saved as C:/Users/Sachin/xilinxworkspace/Conv10/Debug/_sds/reports/sds.log
ERROR: [SDSoC 0-0] Build failed
make: *** [Conv10.elf] Error 1
Does SDSoC support half precision data type? If so, how to fix this issue.
Try adding "-DHLS_NO_XIL_FPO_LIB" to your compilation settings.
@bssachin somehow you are not linking with the proper xilinx library which implements the FP IP. You need to figure out what library to link and add it to your -L list show at the bottom of the log here. Alas I don't remember off-hand what that library is called.
May I ask how could I find the 'compilation settings' option in SDSoC environment?
Thank you very much
SDSoC is built on Eclipse. In Eclipse, if you right click on the blue project folder at the bottom of the pop-up menu is "C/C++ Build Settings".
Sam
Do you mean 'C/C++ Build' -> 'settings' -> 'Command'?
Thank you very much
