marchetto
System Specs for SDx Software
Hi All,
Sorry for my stupid questions i'm a newbie with fpga and SDx Accel software. But on system specs i've read that the recommended RAM size was 80GB!
If i want to try the software on my PC with 16GB of RAM and compiling the example, it wouldn't be possible?
Why is necessary a lot of RAM for this development tool?
rsarkari
Hi @marchetto ,
The minimum system memory requirement is 64 GB. System memory refers to RAM + swap/virtual memory.
You can find out available system memory using the command below on Linux bash:
free -gt
This will display the total system memory available in GBs. If it is more than 64 GBs, you are good to go.
Kindly note- Please mark the Answer as "Accept as solution" if the information provided was helpful.
Give Kudos to a post which you think was helpful and reply oriented.
rsarkari
Hi @marchetto ,
free -gt
