fpga_boy
Typing the incorrect host ID when applying for the SDSoc license
购买了ultra96的开发板,但是申请sdsoc license主机选择错误,现在不能正常使用。开发板附送的sdsoc许可证是不是就废了?有没有补救的方法啊?刚刚到手。。。。。。。。。。Snipaste_2019-12-24_16-28-28.png
graces
You can rehost in the license applying page.
From UG973:
Rehost: Change Node-Locked or License Server Host ID for a License File
1. From the Manage Licenses Tab, select the license file you wish to rehost.
2. Click Modify License.The Modify License screen displays.
3. Go to System Information.
4. Change or add new Host ID and/or Host Name by using the drop-down list and text entryboxes respectively.
5. Click Next button twice and then click Accept to accept the Affidavit of Destruction.
graces
From UG973:
graces
要注意的是对于end user账号,rehost操作不是无限次的。
Administrators are allowed to reallocate product entitlements five times per major release. End users are allowed to reallocate product entitlements three times per major release.
fpga_boy
Thank you!
