gdufourcq
UBUNTU 18.02: "rtl_kernel/rtl_adder_pipes" Example design not working
I'm using the example design "rtl_kernel/rtl_adder_pipes" synthesized with SDx 2018.3 for Alveo U200.
When trying to run the example design on my platform it works perfectly when running CENTOS 7 but hangs forever after "enqueuTask" when using UBUNTU 18.02.
I did the same test targeting AWS F1 board, same result: OK with CENTOS7, hanging with UBUNTU 18.02.
Any idea of the root cause?
hongh
Refer to UG1238, the supported operating system is as below and Ubuntu 18.02 is not supported.
Linux, 64-bit:
Ubuntu 16.04.4, 18.04
CentOS 7.4, 7.5
RHEL 7.4, 7.5
gdufourcq
Hi Hongh,
Argh! It is a typo on my side. I meant "Ubuntu 18.04.2 LTS (Bionic Beaver)" not Ubuntu 18.02 (which does not exist).
So the issue stills...
Have you tried to run the 2019.1 "rtl_adder_streams" example on Ubuntu 18.04.2 ?
gdufourcq
Did anyone try to run the example design on Ubuntu 18.04.2?
I've also tried with 16.04 as proposed ... same error
gdufourcq
Up!
