lacewang
Use the SDSOC to speed up the algorithm and run problems on the zedboard
   Recently, I was studying the acceleration of image processing algorithm on zedboard. When I use SDSOC to generate startup files, After electric start of the board,the program will stop automatically, as shown in the following figure.111.jpg
Here's my code
#include "gaosi.h"
#include <stdio.h>
//#include <Windows.h>
#pragma SDS data sys_port(kern:AFI,src:AFI, dst:AFI)
#pragma SDS data mem_attribute(kern:PHYSICAL_CONTIGUOUS)
#pragma SDS data mem_attribute(src:PHYSICAL_CONTIGUOUS)
#pragma SDS data mem_attribute(dst:NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data access_pattern(kern:SEQUENTIAL)
#pragma SDS data access_pattern(dst:SEQUENTIAL)
#pragma SDS data access_pattern(src:SEQUENTIAL)
#pragma SDS data copy(kern[0:10*10],src[0:rows*cols], dst[0:rows*cols])
void Convolve1DWidth(float kern[100], int dim, float src[307200], float dst[307200], int rows, int cols)
//#define DST(ROW,COL) ((float*)(dst + (cols)*ROW))[(COL)]
//#define Src(ROW,COL) ((float*)(src + (cols)*ROW))[(COL)]
int i, j;
//int ii=0;
for (j = 0; j < rows; j++)
for (i = 0; i < cols; i++)
#pragma HLS PIPELINE
int p;
float pixel = 0;
int col;
int cen = dim / 2;
float temp1 = 0;
float temp2 = 0;
//printf("ConvolveLoc(): Applying convoluation at location (%d, %d)\n", i, j);
for (p = 0; p < dim; p++)
col = i + (p - cen);
if (col < 0)
col = 0;
if (col >= cols)
col = cols - 1;
//pixel += *kern++ * Src(j, col);
//pixel += *(kern+p)*(*(src + j*cols+col));
temp1 = *(kern + p)*(*(src + j*cols + col));
temp2 = pixel;
pixel = temp1 + temp2;
if (pixel > 1)
pixel = 1;
*dst++ = pixel;
The function above is the function I want to accelerate, nested in the following function
int BlurImage(CvMat * src, CvMat * dst, float sigma)
float* convkernel;
int dim = (int)MAX(3.0f, 2.0 * GAUSSKERN * sigma + 1.0f);
float *array1 = (float *)malloc(sizeof(float)*src->rows*src->cols);
float *array2 = (float *)malloc(sizeof(float)*src->rows*src->cols);
for (unsigned int i = 0; i < src->rows; i++)
for (unsigned int j = 0; j < src->cols; j++)
array1[i*src->cols+j] = *(src->data.fl + i*src->cols + j);
CvMat *tempMat;
tempMat = cvCreateMat(src->rows, src->cols, CV_32FC1);
// make dim odd
if (dim % 2 == 0)
dim++;
convkernel = GaussianKernel1D(sigma, dim);
Convolve1DWidth(convkernel, dim, array1, array2, src->rows, src->cols);
cvInitMatHeader(tempMat,src->rows,src->cols, CV_32FC1, array2);
Convolve1DHeight(convkernel, dim, tempMat->data.fl, dst->data.fl, tempMat->rows, tempMat->cols);
cvReleaseMat(&tempMat);
return dim;
Can anyone help me solve this problem? Thank you very much.
lacewang
    I solved this problem by adjusting the parameter order of the function and adding a return value to the function.
lacewang
anyone else?
t_kuha
Which version of SDSoC are you using?
lacewang
lacewang
I using the 2015.4
