Using RTL kernel in Vitis Issue
Hi, I've followed RTL Kernel Wizard Flow & Vivado Design Suite - RTL Design to create Vadd_A_B.xo successfully.
Now, in the Using the RTL Kernel in a Vitis IDE Project, I met the 2 issues in "Build the Project" section.
Q1: Where is vadd.cpp? Is it the typo for host.cpp?
Q2: According to the following picture's instruction, the rtl_ke_t2-Default config will be created automatically.
However, my Run Configurations is blank...
Do I miss some steps or do I can add it by myself?
Any help will be highly appreciated!
Yes, the vadd.cpp seems to be a typo for host.cpp.
Th Run configuration can be accessed from the Run command in the Assistant view rather than from the top-level tool bar menu. The Assistant view is in the lower left side of the IDE.
Otherwise, in your blank Run Configurations window you can select the "New Configuration" button.
