Using xfOpenCV from multiple threads
Greetings,
I'm using the ZCU104 evaluation kit and my hardware accelerated functions are only using around 20% of the FPGA resources. I would like to instantiate four copies of it and run them from four different threads; however I can't find any multithreaded examples in the xfopencv-2018.2 examples folder. Does reVISION support multiple-instantiation of hardware functions and invoking from multiple threads? If so are there examples.
Many thanks,
- Malcolm
Re: Using xfOpenCV from multiple threads
Hi @malcolmnixon
You can absolutely use multiple threads in xfopencv based applications.
Please refer below example for multi-thread implementation,
https://github.com/Xilinx/SDSoC_Examples/tree/master/cpp/getting_started/multi_threading
Below example is multiple hw instances,
https://github.com/Xilinx/SDSoC_Examples/tree/master/cpp/getting_started/multiple_hw_instance
Best Regards,
Nutan
Best Regards,
Nutan
Hi @malcolmnixon
Best Regards,
Nutan
Best Regards,
Nutan
