dave74321
Vitis 2019.2 with applications with both C and C++ code
Previously with SDK 2018.2 I had a project that was generally C code with some C++ files.  Therefore the project was created as a C project and the files that were C++ had their build options individually changed.
However with Vitis 2019.2 I can find no options to set the build options for individual files.
In Vitis 2019.2 I have created a C++ application which has both C and C++ files in it, but I get C++ errors and warnings on the C files.
What should I do to have an application that has both C and C++ files in it?
>>>28 JAN 2020>>>i.e. JPEGs below showing that in SDK there are "Tool Chain Editor" settings but in Vitis there is not.
abouassi
The feature will be available starting from 2020.2
Abdallah
abouassi
Hi @dave74321,
This feature is not working in Vitis. I have reported that internally to our development team.
Thanks for pointing this out.
Abdallah
akozak
@abouassi Any update on this?
MKHen
Hi @abouassi
I am interested in this topic as well.
I want to use a separate FreeRTOS implementation (not the build in one) in my C++ project and I am not able to compile.
Greetings.
abouassi
Abdallah
MKHen
Thank a lot @abouassi for the information.
Are you allowed to give a hint about the release date?
