Vitis 2020.1 Emulation-SW error
I try to reproduce the vector_add example in Vitis 2020.1 with zcu102_base platform.The build is successful but when i run launch on emulator i get the following errors.Thanks in advance
The problem solved!
sudo apt install net-tools and everything runs ok!
The problem solved!
