maty
Vitis Back Button?
I recently bit the bullet and updated to Vitis. So far it's going OK, simple tasks aren't as simple anymore, but it's probably all a learning curve.
However, I cannot believe that this would of gotten removed, the back button... I use "ctrl + click" everywhere to get me to inside the function call, how do I go back to where I came from? Another common shortkey for this is "alt + left." I looked through the shortcut preferences, did a search for "back" and "previous" and played with most of those settings, to no avail.
Has anyone gotten this to work? I would like to click the back-button on my mouse and go back to where I came from last.
Please and thank you, this is driving me crazy.
maty
Last time I'll bump this post.
Anyone knows? It's slowing me down quite a bit, I can't go back to the last file/function call that I came from..
kschmidt
After hour or so of searching I've give up and use Emacs or Visual Studio Code with Makefiles.
It looks like this is a bug of Eclipse and nobody knows how to fix this. Remaping to other keybindings does not work eighter. Its frustrating, but on the other side I learn much more with Makefiles and other editors.
