Vitis Emulation-HW failed with libdpi.so:undefined symbol
Hello, I want to use vitis to accelerate my application based on ZCU102. For learning this new tool, I create a platform following UG1393 Chapter 51, and generate linux image using scripts in https://github.com/Xilinx/Vitis_Embedded_Platform_Source. After building the platform project, I create a application project, which is the example project Vector Add. I build the application project and the Emulation-SW is successful. But When I running Emulation-HW with unchecking "Launch Emulator in GUI mode to display waveforms", the vitis log generates an error: ./xsim.dir/designed_1_wrapper_behav/axsim:symbol lookup error:/home/zhangkai/newdisk/newXRT_project/app02/Emulation-HW/_vimage/rundir/behav_gdb/xsim/libdpi.so:undefined symbol:_ZTI14remoteport_tim When I running Emulation-HW with checking "Launch Emulator in GUI mode to display waveforms",the Vivado IDE is shown and generate an error in Vivado IDE: ERROR:[Simtcl 6-50]Simulation engine failed to start:Simulation exited with status code 127.Please see the TCL Console or the Messages for details. What I should do to get correct Emulation-HW results? Thanks!
Hi @zhangkai
Please let us know if you could fix the issue.
If yes, please share the workaround with the community.
Best Regards,
Nutan
I have the same error "undefined symbol: _ZTI14remoteport_tlm".
Did you find a solution?
Kind Regards,
Danijela
