kdavis119
Vitis Emulation-SW Error
I have built a custom platform.  I am using the Vector Addition template as a "hello world" type application.  I am successfully able to compile and run the contents of the built SD card on my ZCU104 when I build it for Hardware settings.
However, if I try to use Emulation-SW or Emulation-HW, I am unable to start any sort of debug session.  I can build without errors, but when I launch the Emulation-SW, QEMU errors out with:
"Wrong Image Format for bootm command
ERROR: can't get kernel image!"
How can I take advantage of the emulators on my custom platform instead of having to move to the hardware for every single little change ?
nutang
Hi @kdavis119
Please let me know
1. Host machine - linux or Windows
2. Vitis version - 2019.2 or 2020.1
Best Regards,
Nutan
kdavis119
I'm using a host machine running linux / Ubuntu 18.04.4 LTS
Vitis version is 2019.2
kdavis119
I also don't know if it is of note, but the OS for my application is Linux and my petalinux build was configured to have the rootfs in ext4/SD card mode.
akasat
Have you looked at the recently released Vitis 2020.1 platforms. The new Vitis base platforms and boot configuration is built to support EXT4/SDCARD boot. There is also a pre-built linux image and rootfile system available in binary form which can be used. I would recommend going through the latest 2020.1 platform and if possible move to Vivado/Vitis 2020.1. There are several changes in the build and flow to enable this and having a cleaner starting point will make it easier to get started.
https://github.com/Xilinx/Vitis_Embedded_Platform_Source/tree/master/Xilinx_Official_Platforms
kdavis119
I am unable to move beyond 2019.2 due to some dependencies beyond my control on the version.
