clarkm2
Vitis + FreeRTOS/OpenAMP
Hello, I’m having a difficult time with Vitis (Vivado 2019.2). I’m trying to create an OpenAMP example application (echo-test) based on FreeRTOS for the Trenz TE0820. Vivado and Petalinux are working as expected, so I'm now trying to port my RPU firmware. I'm doing the following steps, which results in an exception:
  1. Create Application Project
  2. Created a new platform based on XSA
  3. Domain: psu_cortexr5_0, freertos10_xilinx, C, Generate boot components
  4. Select OpenAMP echo-test
  5. Error: Failed to create platform for application project.
An exception occurred while trying to add domain.
Failed to generate the bsp sources for domain.freertos10_xilinx_domain
Details: WARNING: [Hsi 55-2033] Core openamp_v1_5 depends on libmetal_v1_4 which is an old version. Latest version libmetal_v2_0 exists and will be copied
Failed to generate cmake files.
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_openamp_v1_5::generate : Failed to generate cmake files.
    while executing
"error "Failed to generate cmake files.""
    (procedure "::sw_openamp_v1_5::generate" line 86)
    invoked from within
"::sw_openamp_v1_5::generate openamp"
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
I've also tried to create a platform w/o an application, and I'm getting the same error message after enabling libmetal and OpenAMP while regenerating the BSP sources. I've attached my XSA file.
jovitac
Please see forum thread here where the fix has been posted
https://forums.xilinx.com/t5/OpenAMP/Vitis-2019-2-unable-to-select-libmetal-and-openamp/td-p/1063722
jovitac
I was able to create an OpenAMP echo-test project with freeRTOS using your xsa.
When you select the template, it should select the right library versions for both openamp and libmetal when it generates the bsp.
There is a help tab on top, can you click on that and show me what you have for About Vitis IDE
Can you create a FreeRTOS hello world application for R5?
clarkm2
I was able to create the FreeRTOS hello world application for the R5, and I didn't expereince any issues with Vivado 2019.1. I'm going to try to reinstall Vitis.
About Vitis IDEAbout Vitis IDE
jovitac
Which OS are you using?
clarkm2
Windows 10. I'll give Ubuntu 16 a try tomorrow.
jovitac
The test I did was on Ubuntu 16.
I'm seeing the issue on Windows 7 when adding a libmetal library to bsp in standalone_domain. There might be a similar issue in Windows 10 as well.
I have created a CR for this. Will keep you posted when we have a fix
gary.boudreaux
I am also running into the same issue as well on Vitis 2019.2, Windows 10 version.
I try to create a "New Application Project". I select the default "zed" XSA version that comes with vitis.
I select either CPU version ("ps7_cortexa9_0 or 9_1) as a standalone C project.
I select the OpenAMP echo-test template and recieve the following error:
Failed to generate the bsp sources for domain.standalone_domain
while executing
invoked from within
If I select a template that doesn't involve openAMP or Libmetal. The project successfully is created. else, I recieve the error above.
anx1234
I also saw this problem today.
My setup:
1) windows 10, xilinx vitis 19.2 (with the update)  and
2) windows 10, vmware workstation 15.5 pro, ubuntu desktop 19.04.2, xilinx vitis 19.2 (with the update)
I tried: application project, zcu104 eval board (xsa from bsp), arm cortex r5, standalone .
1) gives the error message
2) does not give the error message (creates the platform project, creates the application project, builds)
I did not try to run it on the target yet (target is zcu104 eval board).
jovitac
