lmaxeniro
Vitis HW emulation report Vivado version mismatch
Dear supporter,
I meet such complaint during Vitis HW-EMU:
"XCLBIN used is generated with Vivado version 2020.1 where as it is run with the Vivado version 2019.2 which is not compatible"
The problem happens after I upgrade the Vitis from 2019.2 to 2020.1 -- actually, my Vitis 2020.1 installation is alongside from the 2019.2, under different paths
my 2019.2 are under /tools/Xilinx and my 2020.1 are under /opt/Xilinx.
I tried launch up Vivado from Vitis--it is the right version (matched).
Then I tried the "vivado" under the command line--it launched up the vivado 2019.
This means during my 2020.1 installations some path or symbol link does not update correctly (I used the batch install)?
Can you please suggest a solution to solve this?
hongh
Could you try to source "settings64.sh" under "install_dir/Vivado/2020.2" before launching Vivado?
hongh
lmaxeniro
It is my bad, back to check my bashrc I source the wrong script--should be "settings64.sh", but I did for "settings64-Vitis.sh", that explains why problem happen.
Thanks for the hint.
