rpa
Vitis Library (Data Compression) : Demo vs Test
I am interested in using one of the libraries within Vitis (Zlib L2 https://github.com/Xilinx/Vitis_Libraries/tree/master/data_compression/L2); I decided to take a look at examples included but found that 2 were included: tests and demos. I was just wondering what's the difference between the 2 of them and which one would be more suited for testing performance. I was thinking of using the library to compress with a file as an input, maybe as a memory stream and having an output directly as a file. The current literature doesn't seem to cover this in depth for Vitis Beginners. Thanks
Tags (2)
