stzog
Vitis Vision Libraries error on build
Hi to all!
I have installed Vitis Vision Libraries examples  and when i try to build in vitis i get the following error....
/home/stavros/pfm2/dilation/libs/xf_opencv/L1/include/common/xf_headers.hpp:23:10: fatal error: opencv2/opencv.hpp: No such file or directory
   23 | #include "opencv2/opencv.hpp"
compilation terminated.
To mention that i have installed opencv 3.4 and the opencv.hpp exists in the folder opencv2....Why cannot find it?
Any help guys?
Davix
If you use Vitis Gui you must right click on the project shown in the Assistant panel and go to settings. On the left side you have to open your project and you will find three sub-section. You have to open the sections with the label "<your_project>_kernels" and "<your_project>" and select one of SW_EMU/HW_EMU/HW (it depend on the purpose you are compiling for), and click on "edit toolchain compiler settings". Under "Tool Settings" section, select the folder includes and, on the right, add the path as i mentioned before (in this case you don't have to add the -I because it will do automatically). I also suggest you to go in the libraries folder, which is just below, and add the path to the opencv libraries, and the common libraries of opencv (core, imgproc, imgcodecs). I recommend to to this procedure for both section i mentioned before, which are "<your_project>_kernels" and "<your_project>". Then click apply and close and build your project.
Davix
Hi @stzog ,
I already faced this kind of problem. I solved it simply including the path of the opencv2 folder into the CFLAGS of the project. Hope this can help.
stzog
@Davix Thanks a lot for your answer.
Can you be more specific how to do this?
Davix
If you are using Vitis hls gui, you can change the settings of your project by right click on you project and choose settings. On the right of the panel, go to simulation/synthesis, click on the file you have and click "CFLAGS" on the left side. Than you have to include the path of your opencv2 folder inserting the following: "-I <path_to_opencv2_folder>". For example, if the path of your opencv2 folder is /home/user/Documents/opencv2, you have to insert "-I /home/user/Documents/"
stzog
@Davix
Hi my friend
I use Vitis Gui and not Vitis Hls.Is there any difference?
Davix
stzog
Many many thanks i wil try it!!!
The strange thing is that in my other laptop with same setup the examples runs without problem....
stzog
@Davix
Now i get the following error....
Screenshot from 2021-01-12 20-14-22.pngScreenshot from 2021-01-12 20-13-38.png
Davix
can you post the entire errors?
