freddyD777
Vitis missing Vivado Design Suite features
I would like to be able to apply Synthesis retiming and Post-route phys_optimization to my kernels in Vitis Accel. I cannot find a way to do this through the Vitis GUI. I see that there is a way to open an implemented project from Vitis in to Vivado. And from there I can change such settings. Although I am unsure if the result in Vivado will be linked to my Vitis project.
Is there no way to do this directly in Vitis? If not, then is opening the project in Vivado the solution?
hongh
Hi, @freddyD777 ,
Below is the example link option for you:
v++ --link --vivado.prop run.impl_1.STEPS.POST_ROUTE_PHYS_OPT_DESIGN.IS_ENABLED=true
--vivado.prop run.impl_1.STEPS.POST_ROUTE_PHYS_OPT_DESIGN.ARGS.DIRECTIVE=Explore
--vivado.prop run.my_rm_synth_1.STEPS.synth_DESIGN.ARGS.RETIMING=true
The synth run name "my_rm_synth_1" may change with different shell or tool version, and you need to confirm it in the VPL generated project.
randyh
Have you reviewed these sections of the User Guide?
https://www.xilinx.com/html_docs/xilinx2021_1/vitis_doc/buildingdevicebinary.html#hnw1523048617934
You can setup Tcl script that can be run as part of the Vitis build process. You can select specific synthesis and implementation options for your design runs, or you can interactively use the VIvado tool and then use the saved results to generate the bitstream for your Vitis xclbin.
hongh
Hi, @freddyD777 ,
