sngo
Vitis platform build errors
I am doing a simple hello world and LED control with the zcu 104 exported hardware from Vivado.  I was able to get this working with two domains in the platform.  However, it took a couple of days to get this to build error free.  Everytime I would build it would be a different error, and eventually none.
I then wanted to try to get 4 domains and 4 apps working.  I am on 2.5 days of building this platform.  I have not been error free, and the errors are not consistent.
Has anyone else experienced this?  Why does this happen?  Was Vitis released too soon?
nutang
Hi @sngo
Please give us more details on Vivado design.
Can you share the XSA file?
Best Regards,
Nutan
sngo
When I try to attach it I get this error
sngo
I have done this design without the timer and LED_CTRL (I just recently added them in.  It is not a complicated design.  It is just for me to gain and understanding of how things work.
rajut
Please zip the XSA and share it, we will look into it.
Raju
