Vitis sw emulation stalls with message error
Hi to all!
I have implemented in Vitis a gray image conversion algorithm. The project is based on Vector add example.
When i give as input-image_size a large image and set buffer size above 2048 the sw emulation stalls and gives me the message "software emulation of compute unit(s) exited unexpectedly".
the kernel code is....
#define BUFFER_SIZE 2048
#define IMAGE_SIZE 3780
#include <stdio.h>
#include <string.h>
const unsigned int c_size = IMAGE_SIZE/BUFFER_SIZE;
extern "C" {
void grayconvert(unsigned char *image, unsigned char *gray_image, int size)
	#pragma HLS dataflow // enable Pipelining
	unsigned char v1_buffer[BUFFER_SIZE];   // Local memory to store vector1
	unsigned int vout_buffer[BUFFER_SIZE]; // Local Memory to store result
	read1:
	for (int j = 0; j < BUFFER_SIZE; j++) {
		#pragma HLS LOOP_TRIPCOUNT min=c_size max=c_size
		#pragma HLS PIPELINE II=1
		v1_buffer[j] = image[j];
	Gray:
	for (int j=0; j<BUFFER_SIZE; j++){
		vout_buffer[j] =( 18*v1_buffer[3*j]+ 37*v1_buffer[3*j+1]+ 7*v1_buffer[3*j+2])/64 ;
//burst write the result
	write:
		 gray_image[j] = vout_buffer[j];
 After debugging with printfs i noticed that the problem is in the Gray for loop and buffer size.
Any idea would be precious.
Is there a log file you can share?
@stephenm
Hi!
Which log file specifically you want me to send?
