kallensf
Vitis: where is 'Import Examples' feature?
In 2019.1 SDK, system.mss -> v_hdmitxss -> Import Examples -> TxOnly
This creates an app with 28 source files, a complete HDMI TX app that can configure the HDMI TX block in the PL and can be compiled and run.
Where is the equivalent in Vitis, if it exists?
rajut
Once you have created your application, click on Modify BSP settings, and expand the Peripheral Drivers and you can see all the Import Examples of different drivers. Please see the below screen shots for reference
Raju
rajut
Raju
kallensf
Thanks for the help!
