prateekmohan1
Vivado Exporting XSA - Application Acceleration Development Flow
I am just starting to understand how the Acceleration flow works with Vivado and Vitis. I saw that in the Vitis Document UG1393, there is a flow diagram that specifies how to run an "Application Acceleration Development Flow"
This was on Page 551 on the v2020.2 document of UG1393.
Now, what I'm trying to figure out is how to perform an export of an XSA file specifically for "Application Acceleration Development Flow". I've exported XSA files before (by going to File -> Export -> Export Hardware) but how do I export it for this?
graces
Please refer to the following doc:
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/create_embedded_platforms.html#vcm1596051749044
prateekmohan1
Thanks for the quick reply! So I want an extensible Vitis platform. Perfect, I will try that.
stephenm
