waterpiggy
Where is the toggle HW/SW in vitis?
I used the SDx 2019.1, and I used the Toggle HW/SW function.
I install the Vitis Software Platform. But, I can not find the Toggle HW/SW.
How can I use this function in the Vitis platform?
rajut
Currently we have a defect in Vitis, where the Toggle HW is not working from Explorer tab.
Please use the Add Hardware Function from the Project editor.
Raju
hongh
Hi, @waterpiggy ,
Please refer to the below link:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk1031919590.html#vyq1504034328190
syedz
@waterpiggy
Did you select the application project after invoking vitis? The vitis is very similar to SDAccel so you should see the sw/hw as shown below:
--Syed
rajut
Raju
