saltedfishlz
Why ‘copy’ pragma only transfer data less than 8MByte?
Hello, I am dealing with a project about Convolution Neural Network.
I used 'copy', 'AXI_DMA simple'and 'sequential'. I think that will instruct IDE to generate a FIFO-based interface.
However, from document 1027, we can see that this kind of interface can only transfer data less than 8 MB. It means that I can not finish processing a single layer in CNN during a single call of hardware function,  even if data can ' flow ' through the hardware function.
I wonder why this restriction of data size is necessary, since FIFO-like interface can work nonstop.
Also, I want to handle the problem. How can I get more than 8 MB data (exactly,  >= 8 MB ) in a single call of hardware function?
I know that pragma 'ZERO_COPY' can deal with this. Howerver, it seems to slow to copy data from ZC706's shared memory from PS side to PL side, and its latency is too high.
hbucher
@saltedfishlz
SDSOC uses Vivado inside. What you want perhaps to do is to create a custom platform.
Check page 146 on UG1146
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1146-sdsoc-platform-development.pdf
hbucher
@saltedfishlz
8M is the hardware limit.
I think it is defined somewhere in xaxidma.h or xaxidma_hw.h
jhwang
Precisely as Henry explains.  And to be clear, the SG-DMA does not have this transfer size restriction.
saltedfishlz
Can I break this limit manually?
Because I think DMA_SG is too slow.
By the way, may I ask the reason why ZC706's DRAM memory on PL side seems faster than that on the PS side?
Also, I wonder why ZC706 uses SODIMM DRAM for FPGA and component DRAM for ARM CPU, while ZCU102 es2 uses SODIMM DRAM for ARM CPU and component DRAM for FPGA.
If I want to realize the MAXIMUM bandwidth for data transfer, what should I do?
hbucher
@jhwang
SGDMA - I believe the individual BDs are still subject to the limit, is that correct?
hbucher
@saltedfishlz The GP/HP ports are much slower than what DDR3/4 can deliver. If I remember well each HP port is 256 Mbps while DDR can go 5 Gbps.
So try to keep everything "fast" and streaming on the PL side
saltedfishlz
Did you mean that I should use 'MIG' if I have huge 'static' data (data that won't change when application is running, for example, weight matrix in CNN forward inference)?
If I use MIG, how to initialize the data in the PL side memory? Use zero_copy?
saltedfishlz
I wonder how do the most experienced engineers use SoC with ARM processor in CNN applications.
Should I use ARM CPU to continuously copy data to PL ? I think this method can reduce latency as well as FPGA BRAM consumption compared with ZERO_COPY. Is that right?
hbucher
@saltedfishlz
Yes, that is why you have DDR on the PL side. The Zynq is primarily for very high level, serial algos that benefit from runing at a much higher frequency.
With HBM (high bandwidth memory) this all will be past though.
https://forums.xilinx.com/t5/Xcell-Daily-Blog/Xilinx-Virtex-UltraScale-FPGAs-incorporate-32-or-64Gbits-of-HBM/ba-p/732029
hbucher
@saltedfishlz Initialization: I have never had the need to do it really, especially with zeros. Because when you use the memory you usually overwrites it anyway.
But if you need to initialize data structures, you can have a global register (static bool initialized = false) and check it when the HLS function is executed. If it was not initialized then you proceed in a loop setting values to zero.
Or you might create another HLS component "MemoryInitializer" and call it from the PS side when the program starts.
Or you can just straight set all to zero from the PS but even a loop from the PL side will take several seconds, depending on the size.
hbucher
@saltedfishlz
If you take away all the hype, CNNs are very very simple algorithms that can be easily coded in HLS. We do this all the time.
But typically we do the training outside on large clusters (Amazon etc) and transfer the weights to the PL DDR at boot time.
So we only have the predict part of the algo in the device, which is just 20% of the entire AI codebase.
saltedfishlz
Thank you for your kindness. I am a sophomore undergraduate in China. Some of my description may be inexact and ambiguous. I am sorry for that.
Actually, 'Initialization' is to load filter data in CNN from external storage or memory (for example, the PS side DRAM) to PL side DRAM.
By the way, to read data from PL side DRAM, is hierarchical memory system beneficial ?
Thanks a lot. (I was sleeping before)
hbucher
@saltedfishlz Beneficial in what terms? Speed? Yes.
You can read more about it here
https://www.xilinx.com/support/documentation/white_papers/wp485-hbm.pdf
saltedfishlz
Senior, thank you very much.
Is there any tools for SDSoC and SDAccel IDE to generate MIG port for PL side?
I haven't seen any instruction in Xilinx's document for SDSoC
Thanks a lot
Zheng Liang, Peking University, China
hbucher
@saltedfishlz It depends on your board. Some boards do not have any DDR on the PL side - I think the Zybo is an example.
On both the zc706 and zcu102 you can see the DDR memory on the Board panel (in Vivado).
You can just drag it to your board design.
saltedfishlz
Oh, thanks a lot.
Actually, I haven't used Vivado for managing CPU. I learned digital logic last semester and only use Vivado for Verilog / VHDL design.
This function of Vivado seems user friendly(I hope so), are there any control protocol needed to be specified beforeuse this IP core ? How can I migrate the SDSoC project to Vivado ?
I am deeply grateful.
hbucher
@saltedfishlz
