tetsuo_yamashita
Why is process speed so different from "Release build" and "Release build with estimate performance" ?
I have tried reVision Stack template.
I noticed that process speed is different from "Release build" and "Release build with estimate performance" ?
Release build
root@xilinx-zc702-2017_2:/media/card# ./fileio_bilateral.elf im0.jpg
sigma_color: 7.72211 sigma_space: 0.901059
OpenCV bilateral filter function : elapsed time 130358528
xfOpenCV bilateral filter function : elapsed time 14312978
Minimum error in intensity = 0
Maximum error in intensity = 1
Percentage of pixels above error threshold = 0.00163966 Count: 34
Release build with "estimate performance"
OpenCV bilateral filter function : elapsed time 129989128
xfOpenCV bilateral filter function : elapsed time 1686544070
I verified those data motion report are the same.
Why is it so different ?
skalicky
Hi Yamashita-san,
When using estimate performance, SDSoC inserts a lot additional code to measure the application's performance. For example lets say your application is like:
int main() {
...other code... //part A foo(A); //part B ...more code... //part C return 0; }
and if you mark function foo() for acceleration and estimate performance, then SDSoC will insert instrumentation to measure the "...other code..." run time, foo() run time, and the "...more code..." run time. Then it will give you an overall report that estimates the benefit you might get by accelerating foo() in hardware. It creates this estimation by computing:
other = part A + part C
acc = SW-->HW transfers + acc run time + HW-->SW transfers
total = other + acc
So when you run the application produced by "estimate performance" it will run slower because of this instrumentation. But the point of estimate performance is not that it "compiles your application better/faster", its that it creates that report estimating how much performance you might expect IF YOU DID accelerate that function.
The expectation is that you run estimate performance to get the report. Then decide whether to accelerate the function and implement the design (which takes longer). Estimation is quick.
Sam
skalicky
Hi Yamashita-san,
int main() {
total = other + acc
Sam
tetsuo_yamashita
Hi @skalicky,
I misunderstood that the project had to be build to run early for performance estimation.
Your explanation really helped.
Thank you so much!
