mathmaxsean
Why the subfunction missed in the report ?
I run the sdaccel for the hardware emulation.
There are three subfunctions :
inear_knn_compute1: for(Dtype_uint i=0;i<size;i++){
        #pragma HLS DATAFLOW
        read_feature_or(feature_or, i, &feature_or_temp);
        dist_or = dist_calc_or(feature_or_temp,query_or_temp);
        k_max(i,dist_or, index_or_heap0_temp, dists_or_heap0_temp, KNN*HEAP_D);
After the  compilation from the "system_estimate_pcaf_fpga.hw_emu.xilinx_vcu1525_dynamic_5_1.xtxt" file I can only see the "read_feature_or" and the "dis_calc_or" and "k_max" are missed.
I also added the " #pragma HLS INLINE off" in all the fucntions but it doesn't work.
hongh
Hi, @mathmaxsean ,
You can try to open the HLS project under HW-emu dir:
vivado_hls -p ./XX/Emulation-HW/binary_container_1/krnl_vadd0/krnl_vadd0/krnl_vadd0 &
hongh
Hi, @mathmaxsean ,
Please check whether the missing submodule can be seen in the output of HLS first.
If not, you should turn to HLS board for help.
mathmaxsean
@hongh
What do you mean about the HLS output?
Where can I see this?
hongh
Hi, @mathmaxsean ,
