lygw
Why the utilization doesn't match between Vitis HLS Report and vitis_analyzer ?
I find that in the Vitis HLS Report (path:_x.hw.xilinx_u280_xdma_201920_3/reports/kernel_separate/hls_reports/kernel_separate_csynth.rpt), the utilization of my porject is as shown below:
However, when I open the kernel.xclbin.run_summary in vitis_analyzer, the utilization shown below doesn't match the one in the Vitis HLS Report.
I'm confused and want to know which one is credible.
Thanks for any help!
hongh
In every design stage, we can get utilization report.
Ex: HLS -> synthesis -> Implementation
The utilization after implementation is the most accurate one, and the utilization reports after the other stage are the estimated ones.
To confirm the result, you can open the routed.dcp in Vivado, and run report_utilization command.
hongh
