stzog
XRT error on sw-emulation
Hi to all!
I have implemented o Sobel filter edge detection with 3 kernels in C and i want to pass it to Vitis.
Build is successful but i receive xrt error on sw emulation.
INFO: [SW-EM 09-0] Unable to find emconfig.json. Using default device.
Found Platform
Platform Name: Xilinx
INFO: Reading ./binary_container_1.xclbin
Loading: './binary_container_1.xclbin'
Trying to program device[0]: xilinx_zcu102_base_202010_1
Device[0]: program successful!
XRT build version: 2.6.0
Build hash: 2d6bfe4ce91051d4e5b499d38fc493586dd4859a
Build date: 2020-05-26 18:53:06
Git branch: 2020.1
PID: 663
UID: 0
[Tue Oct  6 17:53:19 2020]
HOST: zynqmp-common-2020_1
EXE: /media/sd-mmcblk0p1/sobel
[XRT] ERROR: program is nullptr
../src/sobelhost.cpp:92 Error calling cl::Kernel krnl_sob(program, "grayconvert", &err), error code is: -44
 Any help to overcome this error would be precious!
kmorris
Hi @stzog, the best way to debug these issues is to run the debugger (bug icon in the toolbar) and step through your kernel code via breakpoints. When doing this, I found a couple of issues.
The first was a missing kernel argument for your imgscan kernel, your host code only specifies 3 arguments, but misses the T variable (threshold from what I could gather). After adding the extra argument with a best-guess value, the next error I saw when stepping through the code is a segmentation fault when entering the below in the grayconvert kernel:
for (int x=0; x<width*height; x++){
gray_image[x] = 0.2989*image[3*x]+ 0.5870*image[3*x+1]+ 0.1140*image[3*x+2] ;
The width and height are not initialized to any value, which can cause the seg fault. When defining them to a value, the kernel seems to process, but I would also check that your values do not exceed the array bounds of the 'image' variable.
Please don’t forget to reply, kudo, and accept as solution!
kmorris
Hi @stzog, is this being run via GUI or command line? If it is command line, I am wondering if you have the XCL_EMULATION_MODE variable set per the instructions here. Your executable appears to be running from /media/sd-mmcblk0p1/sobel, could you double check that the host is actually in this location?
stzog
@kmorris
Hi and thanks for your reply.
It is this being run via GUI not command line.
kmorris
Would it be possible to provide the archived Vitis project to reproduce (File > Export)?
stzog
@kmorris
I attached it!
stzog
Can anybody explain the following error?
Found Platform
Software emulation of compute unit(s) exited unexpectedly
kmorris
After looking at your project, the error can be expanded if you increase your stack size. You can do this in a terminal before starting Vitis:
ulimit -s unlimited
When doing this, the message I get running the emulation is:
[XRT] ERROR: Invalid scalar argument size, expected 4 got 8
ERROR: clSetKernelArg() for kernel "borderscan", argument index 1.
../src/sobelhost.cpp:126 Error calling err = krnl_sob1.setArg(1, buffer_output), error code is: -51
[XRT] WARNING: Profiling may contain incomplete information. Please ensure all OpenCL objects are released by your host code (e.g., clReleaseProgram()).
corrupted size vs. prev_size
stzog
Now i get the following...
Found Platform
Git branch: 2020.1
PID: 742
UID: 0
[Sat Oct 10 11:18:44 2020]
kmorris
Is this happening after setting the stack size and correcting the error I mentioned previously?
stzog
@kmorris
I corrected my code , i followed your suggestion(ulimit -s unlimited before run vitis)
but most of the times a still get the following error when i run sw emulation
Found Platform
Sometimes i get....
Found Platform
TEST PASSED!
Does this mean that sw emulation run succesfully?
stzog
@kmorris
Hi!
Do you have any suggestion?
Moreover is the
 crucial to run correctly the sw-emulation?
stzog
@kmorris
Hi again!
I constantly get the
error.Even if i run ulimit -s unlimited before run Vitis.Any other point to check out to solve this?
kmorris
